<glossary> <dterm>first term definition of first term can continue over multiple lines or paragraphs <dterm>second term definition of second term ... . . .
"Glossary" is automatically used as the heading for the glossary section.
A <dterm> element identifies each term and its definition.
All terms marked with <term> without the nogloss parameter are required to be in the glossary. If the term is not in the glossary, omitted terms are listed in the volume .err file, which is created when you run HelpTag.
An end tag for <glossary> is not required.
