Common Desktop Environment: Help System Author's and Programmer's Guide
Syntax
<memo>
 memo text
 <\memo>
Or:
<memo|memo text|
Memo text is printed in drafts of your help volume if you specify memo in the helptag.opt file. Otherwise, memo text is not printed, especially when you create the final version of the help volume. Memo text, when it appears, is printed in a different typeface. Do not use markup within memo text.
