Common Desktop Environment: Help System Author's and Programmer's Guide
To Include a Special Character
  1. Refer to Chapter 6, Summary of Special Character Entities, to determine the entity name for the character you want to display. Also, note whether it is a built-in special character.
  2. If the character is not a built-in special character, add the following two lines among your other entity declarations (where entity-name is a meaningful name to you):
    <!entity entity-name FILE  "helpchar.ent">  &entity-name;
     &entity-name;
    Also, add this line to your helptag.opt file:
    search=/usr/dt/dthelp/dthelptag
    If the character is built into HelpTag, you can skip step 2.
  3. Wherever you want to display the special character, enter its entity reference:
    &entity-name;
Examples
The entity for the copyright symbol (©) is a built-in special character, so all you have to do to display it is use this entity:
&copy;
To display the uppercase greek letter sigma, you must first include the helpchar.ent file (at the top of your help volume with your other entity declarations) as shown here:
<!entity  SpecialCharacterEntities  FILE   "helpchar.ent">
&SpecialCharacterEntities;
Then you can place the following entity reference where the sigma character is to appear:
&Usigma;
As with any entity, case is not significant in the entity names for special characters.
See Also
