Common Desktop Environment: Help System Author's and Programmer's Guide
To Mark a Glossary Term
    Use the <term> element as shown:
<term>word or phrase<\term>
Or, use the short form:
<term|word or phrase|
Or, use the shorthand form:
++word or phrase++
If the term within the help text isn't spelled exactly the same as the definition in the glossary, you can specify the "glossary form" of the term like this:
<term "glossary form">word or phrase<\term>
Where glossary form is the term exactly as it appears in the glossary. This is useful if the term must be plural in a help topic (because of its context), but must be singular in the glossary.
Terms are displayed using a bold font and automatically become a definition hyperlink. When the term is chosen, its glossary definition appears in a quick help dialog.
Note -
If you mark a term that you intentionally do not define in the glossary, add the nogloss attribute to the <term> element. This allows the term to be displayed in the bold font used for terms, but without creating a link to the glossary.
Examples
If your glossary has a definition for the term "widget", you can enter it as a term like this:
A ++widget++ is the fundamental building block of OSF/Motif user interfaces.
If the glossary entry is "widget", but you need to use the plural form within the sentence, you could enter the term like this:
<term  "widget">Widgets<\term> are the fundamental building blocks
If you want to enter the same term, but you either don't want to include it in the glossary or you don't want it to be a hyperlink, use the nogloss parameter like this:
<term nogloss> Widgets<\term>are the fundamental building blocks
The equivalent short form is:
<term nogloss|Widgets| are the fundamental building blocks
