To create an execution alias in an application's application defaults file, use this resource specification syntax:
application_name.executionAlias.alias_name: command
Where:
Name or class name of the application that owns the help volume
Keyword that identifies the resource is an alias
Name assigned to the command
Shell command or script to be executed for this link
There is no restriction on the length of the command string. To enter commands with multiple lines, end each line (except the last) with a \ (backslash).
