Common Desktop Environment: Help System Author's and Programmer's Guide
DtNexecutionPolicy Resource
The DtNexecutionPolicy resource enables a system administrator or user to select an appropriate level of security for a given application.
The resource values that can be set are:
Query all execution links.
Query only link commands that do not have execution aliases defined.
Do not execute any execution links.
Execute all execution links.
The default value is help_execute_query_unaliased. Any execution links defined as execution aliases will be automatically executed, whereas the Help System will display a confirmation dialog box for any other execution links.
It is not recommended for the application developer to set the DtNexecutionPolicy because this prevents a system administrator or user from altering the value.
See Also
