x86 Assembly Language Reference Manual
Section Header
The section header table has all of the information necessary to locate and isolate each of the file's sections. A section header entry in a section header table contains information characterizing the contents of the corresponding section, if the file has such a section.
Each entry in the section header table is a section header. A section header is a structure of fixed size and format, consisting of the following fields, or members:
sh_name
Specifies the section name. The value of this field is an index into the section header string table section, wherein it indicates the beginning of a null-terminated string that names the section.
sh_type
Categorizes the section's contents and semantics. Table 3-3 describes the section types.
sh_flags
One-bit descriptions of section attributes. Table 3-2 describes the section attribute flags.
sh_addr
Address where the first byte resides if the section appears in the memory image of a process; a value of 0 indicates the section does not appear in the memory image of a process.
sh_offset
Specifies the byte offset from the beginning of the file to the first byte in the section.
Note -
If the section type is SHT_NOBITS, the corresponding section occupies no space in the file. In this case, sh_offset specifies the location at which the section would have begun if it did occupy space within the file.
sh_size
Specifies the size, in byte units, of the section.
Note -
Even if the section type is SHT_NOBITS, sh_size can be nonzero; however, the corresponding section still occupies no space in the file.
sh_link
Section header table index link. The interpretation of this information depends on the section type, as described in Table 3-3.
sh_info
Extra information. The interpretation of this information depends on the section type, as described in Table 3-3.
sh_addralign
If a section has an address alignment constraint, the value in this field is the modulus, in byte units, by which the value of sh_addr must be congruent to 0; i.e., sh_addr = 0 (mod sh_addralign). For example, if a section contains a long (32 bits), the entire section must be ensured long alignment, so sh_addralign has the value 4. Only 0 and positive integral powers of 2 are currently allowed as values for this field. A value of 0 or 1 indicates no address alignment constraints.
sh_entsize
Size, in byte units, for entries in a section that is a table of fixed-size entries, such as a symbol table. Has the value 0 if the section is not a table of fixed-size entries
Table 3-2 Section Attribute Flags
Flag
Default Value
Description
SHF_WRITE
0x1
Contains data that is writable during process execution.
SHF_ALLOC
0x2
Occupies memory during process execution. This attribute is off if a control section does not reside in the memory image of the object file.
SHF_EXECINSTR
0x4
Contains executable machine instructions.
SHF_MASKPROC
0xf0000000
Reserved for processor-specific semantics.
Table 3-3 Section Types
Name
Value
Description
Interpretation by
sh_info
sh_link
SHT_NULL
Marks section header as inactive; file has no corresponding section.
SHN_UNDEF
SHT_PROGBITS
Contains information defined by the program, and in a format and with a meaning determined solely by the program.
SHN_UNDEF
SHT_SYMTAB
Is a complete symbol table, usually for link editing. This table can also be used for dynamic linking; however, it can contain many unnecessary symbols.
Note: Only one section of this type is allowed in a file
One greater than the symbol table index of the last local symbol.
The section header index of the associated string table.
SHT_STRTAB
Is a string table. A file can have multiple string table sections.
SHN_UNDEF
SHT_RELA
Contains relocation entries with explicit addends. A file can have multiple relocation sections.
The section header index of the section to where the relocation applies.
The section header index of the associated symbol table.
SHT_HASH
Is a symbol rehash table.
The section header index of the symbol table to which the hash table applies.
SHT_DYNAMIC
Contains dynamic linking information.
The section header index of the string table used by entries in the section.
SHT_NOTE
Contains information that marks the file.
SHN_UNDEF
SHT_NOBITS
Contains information defined by the program, and in a format and with a meaning determined by the program. However, a section of this type occupies no space in the file, but the section header's offset field specifies the location at which the section would have begun if it did occupy space within the file.
SHN_UNDEF
SHT_REL
Contains relocation entries without explicit addends. A file can have multiple relocation sections.
SHT_SHLIB
10
Reserved.
SHN_UNDEF
SHT_DYNSYM
11
Is a symbol table with a minimal set of symbols for dynamic linking.
SHT_LOPROC
SHT_HIPROC
0x70000000
0x7fffffff
Lower and upper bounds of range of section types reserved for processor-specific semantics.
SHN_UNDEF
SHT_LOUSER
SHT_HIUSER
0x80000000
0xffffffff
Lower and upper bounds of range of section types reserved for application programs.
Note: Section types in this range can be used by an application without conflicting with system-defined section types.
SHN_UNDEF
Note -
Some section header table indices are reserved, and the object file does not contain sections for these special indices.
