x86 Assembly Language Reference Manual
Symbol Tables
The symbol table contains information to locate and relocate symbolic definitions and references. The assembler creates the symbol table section for the object file. It makes an entry in the symbol table for each symbol that is defined or referenced in the input file and is needed during linking.
The symbol table is then used by the link editor during relocation. The symbol table's section header contains the symbol table index for the first non-local symbol.
The symbol table contains the following information:
st_name
Index into the object file symbol string table. A value of zero indicates the corresponding entry in the symbol table has no name; otherwise, the value represents the string table index that gives the symbol name.
st_value
Value of the associated symbol. This value is dependent on the context; for example, it can be an address, or it can be an absolute value.
st_size
Size of symbol. A value of 0 indicates that the symbol has either no size or an unknown size.
st_info
Specifies the symbol type and binding attributes. Table 3-6 and Table 3-7 describe the symbol types and binding attributes.
st_other
Undefined meaning. Current value is 0.
st_shndx
Contains the section header table index to another relevant section, if specified. As a section moves during relocation, references to the symbol continue to point to the same location because the value of the symbol changes as well.
Table 3-6 Symbol Types
Value
Type
Description
notype
Type not specified.
object
Symbol is associated with a data object; for example, a variable or an array.
func
Symbol is associated with a function or other executable code. When another object file references a function from a shared object, the link editor automatically creates a procedure linkage table entry for the referenced symbol.
section
Symbol is associated with a section. These types of symbols are primarily used for relocation.
file
Gives the name of the source file associated with the object file.
13
15
loproc
hiproc
Values reserved for processor-specific semantics.
Table 3-7 Binding Attributes
Value
Binding
Description
local
Symbol is defined in the object file and not accessible in other files. Local symbols of the same name can exist in multiple files.
global
Symbol is either defined externally or defined in the object file and accessible in other files.
weak
Symbol is either defined externally or defined in the object file and accessible in other files; however, these definitions have a lower precedence than globally defined symbols.
13
15
loproc
hiproc
