x86 Assembly Language Reference Manual
LOCK Prefix (lock)
lock
Operation
LOCK# -> NEXT Instruction
Description
The LOCK # signal is asserted during execution of the instruction following the lock prefix. This signal can be used in a multiprocessor system to ensure exclusive use of shared memory while LOCK # is asserted. The bts instruction is the read-modify-write sequence used to implement test-and-run.
The lock prefix works only with the instructions listed here. If a lock prefix is used with any other instructions, an undefined opcode trap is generated.
bt, bts, btr, btc
m, r/imm
xchg
r, m
xchg
m, r
add, or, adc, sbb, and, sub, xor
m, r/imm
not, neg, inc, dec
Memory field alignment does not affect the integrity of lock.
If a different 80386 processor is concurrently executing an instruction that has a characteristic listed here, locked access is not guaranteed. The previous instruction:
Example
lock
