x86 Assembly Language Reference Manual
Unsigned Divide (div)
div{bwl}	 	r/m[8|16|32]
Operation
AX r/m8 -> AL DX:AX
r/m16 -> AX EDX:EAX
r/m32 -> EAX
Description
div executes unsigned division. div divides a 16-, 32-, or 64-bit register value (dividend) by a register or memory byte, word, or long (divisor). The quotient is stored in the AL, AX, or EAX register respectively.
The remainder is stored in AH, Dx, or EDX. The size of the divisor (8-, 16- or 32-bit operand) determines the particular register used as the dividend.
The OF, SF, ZF, AR, PF and CF flags are undefined.
Example
Perform an 8-bit unsigned divide of the AX register by the contents of the effective address (addressed by the ESI register plus an offset of 1) and store the quotient in the AL register, and the remainder in AH:
divb 1(%esi)
Perform a 16-bit unsigned divide of the DX:AX register by the contents of the effective address (addressed by the EDI register plus an offset of 4) and store the quotient in the AX register, and the remainder in DX:
divw 4(%edi)
Perform a 32-bit unsigned divide of the EDX:EAX register by the contents of the effective address (addressed by the EDI register plus an offset of 4) and store the quotient in the EAX register, and the remainder in EDX:
divl 4(%edi)
