x86 Assembly Language Reference Manual
ASCII Adjust after Addition (aaa)
aaa
Operation
ASCII-adjust AL -> AL
Description
You use aaa only after executing the form of an add instruction that stores a two-BCD-digit byte result in the AL register. aaa then adjusts AL to contain the correct decimal result. The top nibble of AL is set to 0. To convert AL to an ASCII result, follow the aaa instruction with:
or %al, 0x30
The following table shows how aaa handles a carry.
Table 2-8 aaa Handling a Carry
Carry
Action
decimal carry
AH + 1; CF and AF set to 1
no decimal carry
AH unchanged; CF and AF cleared to 0
Example
Adjust the AL register to contain the correct decimal result after an add instruction that stores a two-BCD-digit byte.
aaa
