x86 Assembly Language Reference Manual
ASCII Adjust AX after Multiply (aam)
aam
Operation
AL 10 -> AH mod 10 AL -> AL
Description
You use aam only after executing a mul instruction between two BCD digits (unpacked). mul stores the result in the AX register. The result is less than 100 so it can be contained in the AL register (the low byte of the AX register). aam unpacks the AL result by dividing AL by 10, stores the quotient (most-significant digit) in AH, and stores the remainder (least-significant digit) in AL.
Example
Adjust the AL register to contain the correct decimal result after a mul instruction between two BCD digits:
aam
