x86 Assembly Language Reference Manual
Move Data from String to String (movs)
movs{bwl} m[8|16|32], reg[16|32]
move {bwl} [(E)SI] -> ES: (E)DI]
move {bwl} DS: [(E)SI] -> ES: [(E)DI]
Copies the byte, word, or long in [(E)SI] to the byte, word, or long in ES:[(E)DI}. Before executing the move instruction, load the index values into the SI source- and DI destination-index registers.
The destination operand must be addressable from the ES register; it cannot span segments. A source operand, however, can span segments; the default is DS.
After the data is moved, both the source- and destination-index registers are automatically incremented or decremented as determined by the value of the direction flag (DF). The index registers are incremented if DF = 0 (DF cleared by a cld instruction); they are decremented if DF = 1 (DF set by a std instruction). The increment/decrement count is 1 for a byte move, 2 for a word, and 4 for a long.
For a block move of CX bytes or words, precede a movs instruction with a rep prefix.
Copy the 8-bit byte from the DS:[(E)SI] to the ES:[(E)DI] register.
