x86 Assembly Language Reference Manual
Bit Scan Forward (bsf)
bsf{wl}		r/m[16|32], reg[16|32]
Operation
(r/m = 0) 0 -> ZF (r/m [ne ] 0) 0 -> ZF
Description
bsf scans the bits, starting at bit 0, in the doubleword operand or the second word. If the bits are all zero, ZF is cleared. Otherwise, ZF is set and the bit index of the first set bit, found while scanning in the forward direction, is loaded into the destination register.
Example
bsf 4(%edi), %edx
