Multithreaded Programming Guide
pthread_attr_init(3T)
Use pthread_attr_init(3T) to initialize object attributes to their default values. The storage is allocated by the thread system during execution.
Prototype:
int pthread_attr_init(pthread_attr_t *tattr);
#include <pthread.h>
pthread_attr_t tattr;
int ret;
/* initialize an attribute to the default value */
ret = pthread_attr_init(&tattr);
The default values for attributes (tattr) are:
Table 3-1 Default Attribute Values for tattr
Attribute
Value
Result
scope
PTHREAD_SCOPE_PROCESS
New thread is unbound - not permanently attached to LWP.
detachstate
PTHREAD_CREATE_JOINABLE
Exit status and thread are preserved after the thread terminates.
stackaddr
NULL
New thread has system-allocated stack address.
stacksize
1 megabyte
New thread has system-defined stack size.
priority
New thread inherits parent thread priority.
inheritsched
PTHREAD_INHERIT_SCHED
New thread inherits parent thread scheduling priority.
schedpolicy
SCHED_OTHER
New thread uses Solaris-defined fixed priority scheduling; threads run until preempted by a higher-priority thread or until they block or yield.
Return Values
Returns zero after completing successfully. Any other returned value indicates that an error occurred. If the following condition occurs, the function fails and returns the corresponding value.
ENOMEM
Returned when there is not enough memory to initialize the thread attributes object.
