Multithreaded Programming Guide
Set Scheduling Parameters
pthread_attr_setschedparam(3T) sets the scheduling parameters.
Scheduling parameters are defined in the param structure; only priority is supported. Newly created threads run with this priority.
int	pthread_attr_setschedparam(pthread_attr_t *tattr,
    const struct sched_param *param);
#include <pthread.h>
pthread_attr_t tattr;
int newprio;
sched_param param;
newprio = 30;
/* set the priority; others are unchanged */
param.sched_priority = newprio;
/* set the new scheduling param */
ret = pthread_attr_setschedparam (&tattr, &param);
Return Values
Returns zero after completing successfully. Any other returned value indicates that an error occurred. If the following conditions occur, the function fails and returns the corresponding value.
The value of param is NULL or tattr is invalid.
You can manage pthreads priority two ways. You can set the priority attribute before creating a child thread, or you can change the priority of the parent thread and then change it back.
