Multithreaded Programming Guide
Using adb(1)
When you bind all threads in a multithreaded program, a thread and an LWP are synonymous. Then you can access each thread with the following adb commands that support multithreaded programming.
Table 7-3 MT adb Commands
pid:A
Attaches to process # pid. This stops the process and all its LWPs.
:R
Detaches from process. This resumes the process and all its LWPs.
$L
Lists all active LWPs in the (stopped) process.
n:l
Switches focus to LWP # n.
$l
Shows the LWP currently focused.
num:i
Ignores signal number num.
These commands to set conditional breakpoints are often useful.
Table 7-4 Setting adb Breakpoints
[label],[count]:b [expression]
Breakpoint is detected when expression equals zero
foo,ffff:b <g7-0xabcdef
Stop at foo when g7 = the hex value 0xABCDEF
