Multithreaded Programming Guide
Thread Concurrency (Solaris Threads Only)
By default, Solaris threads attempts to adjust the system execution resources (LWPs) used to run unbound threads to match the real number of active threads. While the Solaris threads package cannot make perfect decisions, it at least ensures that the process continues to make progress.
When you have some idea of the number of unbound threads that should be simultaneously active (executing code or system calls), tell the library through thr_setconcurrency(3T).
For example:
Alternatively, the concurrency level can be incremented by one through the THR_NEW_LWP flag as each thread is created.
Include unbound threads blocked on interprocess (USYNC_PROCESS) synchronization variables as active when you compute thread concurrency. Exclude bound threads--they do not require concurrency support from Solaris threads because they are equivalent to LWPs.
