Multithreaded Programming Guide
Code Locking
Code locking is done at the function call level and guarantees that a function executes entirely under the protection of a lock. The assumption is that all access to data is done through functions. Functions that share data should execute under the same lock.
Some parallel programming languages provide a construct called a monitor that implicitly does code locking for functions that are defined within the scope of the monitor. A monitor can also be implemented by a mutex lock.
Functions under the protection of the same mutex lock or within the same monitor are guaranteed to execute atomically with respect to each other.
