thr_continue(3T) resumes the execution of a suspended thread. Once a suspended thread is continued, subsequent calls to thr_continue() have no effect.
#include <thread.h> int thr_continue(thread_t tid);
A suspended thread will not be awakened by a signal. The signal stays pending until the execution of the thread is resumed by thr_continue().
pthread_t
tid as defined in pthreads is the same as thread_t
tid in Solaris threads. tid values can be used interchangeably either by assignment or through the use of casts.
thread_t tid; /* tid from thr_create()*/ /* pthreads equivalent of Solaris tid from thread created */ /* with pthread_create()*/ pthread_t ptid; int ret; ret = thr_continue(tid); /* using pthreads ID variable with a cast */ ret = thr_continue((thread_t) ptid)
thr_continue() returns zero after completing successfully. Any other returned value indicates that an error occurred. When the following condition occurs, thr_continue() fails and returns the corresponding value.
