Multithreaded Programming Guide
#include <synch.h>  (or #include <thread.h>)
int rwlock_init(rwlock_t *rwlp, int type, void * arg);
Use rwlock_init(3T) to initialize the read-write lock pointed to by rwlp and to set the lock state to unlocked. type can be one of the following (note that arg is currently ignored). (For POSIX threads, see "pthread_rwlock_init(3T)".)
Multiple threads must not initialize the same read-write lock simultaneously. Read-write locks can also be initialized by allocation in zeroed memory, in which case a type of USYNC_THREAD is assumed. A read-write lock must not be reinitialized while other threads might be using it.
Initializing Read-Write Locks with Intraprocess Scope
#include <thread.h>
rwlock_t rwlp;
int ret;
/* to be used within this process only */
ret = rwlock_init(&rwlp, USYNC_THREAD, 0);
Initializing Read-Write Locks with Interprocess Scope
#include <thread.h>
rwlock_t rwlp;
int ret;
/* to be used among all processes */
ret = rwlock_init(&rwlp, USYNC_PROCESS, 0);
Return Values
rwlock_init() returns zero after completing successfully. Any other returned value indicates that an error occurred. When any of the following conditions occur, the function fails and returns the corresponding value.
Invalid argument.
rwlp or arg points to an illegal address.
