Multithreaded Programming Guide
The Producer/Consumer Problem, Using Semaphores
The data structure in Example 4-14 is similar to that used for the condition variables example (see Example 4-11). Two semaphores represent the number of full and empty buffers and ensure that producers wait until there are empty buffers and that consumers wait until there are full buffers.
Example 4-14 The Producer/Consumer Problem with Semaphores
typedef struct {
    char buf[BSIZE];
    sem_t occupied;
    sem_t empty;
    int nextin;
    int nextout;
    sem_t pmut;
    sem_t cmut;
} buffer_t;
buffer_t buffer;
sem_init(&buffer.occupied, 0, 0);
sem_init(&buffer.empty,0, BSIZE);
sem_init(&buffer.pmut, 0, 1);
sem_init(&buffer.cmut, 0, 1);
buffer.nextin = buffer.nextout = 0;
Another pair of (binary) semaphores plays the same role as mutexes, controlling access to the buffer when there are multiple producers and multiple empty buffer slots, and when there are multiple consumers and multiple full buffer slots. Mutexes would work better here, but would not provide as good an example of semaphore use.
Example 4-15 The Producer/Consumer Problem - the Producer
void producer(buffer_t *b, char item) {
    sem_wait(&b->empty);
    sem_wait(&b->pmut);
    b->buf[b->nextin] = item;
    b->nextin++;
    b->nextin %= BSIZE;
    sem_post(&b->pmut);
    sem_post(&b->occupied);
Example 4-16 The Producer/Consumer Problem - the Consumer
char consumer(buffer_t *b) {
    char item;
    sem_wait(&b->occupied);
    sem_wait(&b->cmut);
    item = b->buf[b->nextout];
    b->nextout++;
    b->nextout %= BSIZE;
    sem_post(&b->cmut);
    sem_post(&b->empty);
    return(item);
