Multithreaded Programming Guide
Set a Read-Write Lock Attribute
pthread_rwlockattr_setpshared(3T)
#include <pthread.h>
int pthread_rwlockattr_setpshared(pthread_rwlockattr_t  *attr, int  pshared);
pthread_rwlockattr_setpshared(3T) sets the process-shared read-write lock attribute.
PTHREAD_PROCESS_SHARED
Permits a read-write lock to be operated upon by any thread that has access to the memory where the read-write lock is allocated, even if the read-write lock is allocated in memory that is shared by multiple processes.
PTHREAD_PROCESS_PRIVATE
The read-write lock will only be operated upon by threads created within the same process as the thread that initialized the read-write lock; if threads of differing processes attempt to operate on such a read-write lock, the behaviour is undefined. The default value of the process-shared attribute is PTHREAD_PROCESS_PRIVATE.
Return Value
If successful, pthread_rwlockattr_setpshared() returns zero. Otherwise, an error number is returned to indicate the error.
EINVAL
The value specified by attr or psharedis invalid.
