Multithreaded Programming Guide
#include <pthread.h>
int pthread_rwlock_destroy(pthread_rwlock_t *rwlock);
pthread_rwlock_t  rwlock = PTHREAD_RWLOCK_INITIALIZER;
pthread_rwlock_destroy(3T) destroys the read-write lock object referenced by rwlock and releases any resources used by the lock. The effect of subsequent use of the lock is undefined until the lock is re-initialized by another call to pthread_rwlock_init() An implementation may cause pthread_rwlock_destroy() to set the object referenced by rwlock to an invalid value. Results are undefined if pthread_rwlock_destroy() is called when any thread holds rwlock. Attempting to destroy an uninitialized read-write lock results in undefined behaviour. A destroyed read-write lock object can be re-initialized using pthread_rwlock_init(); the results of otherwise referencing the read-write lock object after it has been destroyed are undefined. (For Solaris threads, see "rwlock_destroy(3T)".)
Return Value
If successful, pthread_rwlock_destroy() returns zero. Otherwise, an error number is returned to indicate the error.
The value specified by attr or rwlockis invalid.
