Multithreaded Programming Guide
Write Lock with a Nonblocking Read-Write Lock
pthread_rwlock_trywrlock(3T)
#include <pthread.h>
int pthread_rwlock_trywrlock(pthread_rwlock_t  *rwlock);
pthread_rwlock_trywrlock(3T) applies a write lock like pthread_rwlock_wrlock(), with the exception that the function fails if any thread currently holds rwlock (for reading or writing). (For Solaris threads, see "rw_trywrlock(3T)".)
Results are undefined if pthread_rwlock_trywrlock() is called with an uninitialized read-write lock.
If a signal is delivered to a thread waiting for a read-write lock for writing, upon return from the signal handler the thread resumes waiting for the read-write lock for writing as if it was not interrupted.
Return Value
If successful, pthread_rwlock_trywrlock() returns zero if the lock for writing on the read-write lock object referenced by rwlock is acquired. Otherwise, an error number is returned to indicate the error.
EBUSY
The read-write lock could not be acquired for writing because it is already locked for reading or writing.
