Multithreaded Programming Guide
Initialize a Mutex
pthread_mutex_init(3T)
Use pthread_mutex_init(3T) to initialize the mutex pointed at by mp to its default value (mattr is NULL), or to specify mutex attributes that have already been set with pthread_mutexattr_init(). (For Solaris threads, see "mutex_init(3T)".)
Prototype:
int	pthread_mutex_init(pthread_mutex_t *mp,
    const pthread_mutexattr_t *mattr);
#include <pthread.h>
pthread_mutex_t mp = PTHREAD_MUTEX_INITIALIZER;
pthread_mutexattr_t mattr;
int ret;
/* initialize a mutex to its default value */
ret = pthread_mutex_init(&mp, NULL);
/* initialize a mutex */
ret = pthread_mutex_init(&mp, &mattr);
When the mutex is initialized, it is in an unlocked state.
The effect of mattr being NULL is the same as passing the address of a default mutex attribute object, but without the memory overhead.
Statically defined mutexes can be initialized directly to have default attributes with the macro PTHREAD_MUTEX_INITIALIZER.
A mutex lock must not be reinitialized or destroyed while other threads might be using it. Program failure will result if either action is not done correctly. If a mutex is reinitialized or destroyed, the application must be sure the mutex is not currently in use.
Return Values
pthread_mutex_init() returns zero after completing successfully. Any other returned value indicates that an error occurred. When any of the following conditions occur, the function fails and returns the corresponding value.
EBUSY
The mutex cannot be reinitialized or modified because it still exists.
EINVAL
The attribute value is invalid. The mutex has not been modified.
EFAULT
The address for the mutex pointed at by mp is invalid.
