Example 4-4 and Example 4-5 show how to take three locks at once, but prevent deadlock by taking the locks in a prescribed order.
typedef struct node1 { int value; struct node1 *link; pthread_mutex_t lock; } node1_t; node1_t ListHead;
This example uses a singly-linked list structure with each node containing a mutex. To remove a node from the list, first search the list starting at ListHead (which itself is never removed) until the desired node is found.
To protect this search from the effects of concurrent deletions, lock each node before any of its contents are accessed. Because all searches start at ListHead, there is never a deadlock because the locks are always taken in list order.
When the desired node is found, lock both the node and its predecessor since the change involves both nodes. Because the predecessor's lock is always taken first, you are again protected from deadlock. Example 4-5 shows the C code to remove an item from a singly linked list.
node1_t *delete(int value) { node1_t *prev, *current; prev = &ListHead; pthread_mutex_lock(&prev->lock); while ((current = prev->link) != NULL) { pthread_mutex_lock(¤t->lock); if (current->value == value) { prev->link = current->link; pthread_mutex_unlock(¤t->lock); pthread_mutex_unlock(&prev->lock); current->link = NULL; return(current); } pthread_mutex_unlock(&prev->lock); prev = current; } pthread_mutex_unlock(&prev->lock); return(NULL); }
