Multithreaded Programming Guide
Yield Thread Execution
Use sched_yield(3R) to cause the current thread to yield its execution in favor of another thread with the same or greater priority.
int	 sched_yield(void);
#include <sched.h>
int ret;
ret = sched_yield();
Return Values
Returns zero after completing successfully. Otherwise -1 is returned and errno is set to indicate the error condition.
sched_yield(3R) is not supported in this implementation.
