Use pthread_setcancelstate(3T) to enable or disable thread cancellation. When a thread is created, thread cancellation is enabled by default.
Prototype: int pthread_setcancelstate(int state, int *oldstate);
#include <pthread.h> int oldstate; int ret; /* enabled */ ret = pthread_setcancelstate(PTHREAD_CANCEL_ENABLE, &oldstate); /* disabled */ ret = pthread_setcancelstate(PTHREAD_CANCEL_DISABLE, &oldstate);
pthread_setcancelstate() returns zero after completing successfully. Any other returned value indicates that an error occurred. When the following condition occurs, the pthread_setcancelstate() function fails and returns the corresponding value.
