The POSIX threads library introduces the ability to cancel threads to threads programming. Cancellation allows a thread to terminate the execution of any other thread, or all threads, in the process. Cancellation is an option when all further operations of a related set of threads are undesirable or unnecessary. A good method is to cancel all threads, restore the process to a consistent state, and then return to the point of origin.
One example of thread cancellation is an asynchronously generated cancel condition, such as, when a user requesting to close or exit some running application. Another example is the completion of a task undertaken by a number of threads. One of the threads might ultimately complete the task while the others continue to operate. Since they are serving no purpose at that point, they all should be cancelled.
There are dangers in performing cancellations. Most deal with properly restoring invariants and freeing shared resources. A thread that is cancelled without care might leave a mutex in a locked state, leading to a deadlock. Or it might leave a region of memory allocated with no way to identify it and therefore no way to free it.
The pthreads library specifies a cancellation interface that permits or forbids cancellation programmatically. The library defines the set of points at which cancellation can occur (cancellation points). It also allows the scope of cancellation handlers, which provide clean up services, to be defined so that they are sure to operate when and where intended.
Placement of cancellation points and the effects of cancellation handlers must be based on an understanding of the application. A mutex is explicitly not a cancellation point and should be held only the minimal essential time.
Limit regions of asynchronous cancellation to sequences with no external dependencies that could result in dangling resources or unresolved state conditions. Take care to restore cancellation state when returning from some alternate, nested cancellation state. The interface provides features to facilitate restoration: pthread_setcancelstate(3T) preserves the current cancel state in a referenced variable; pthread_setcanceltype(3T) preserves the current cancel type in the same way.
Cancellations can occur under three different circumstances:
Asynchronously
At various points in the execution sequence as defined by the standard
At discrete points specified by the application
By default, cancellation can occur only at well-defined points as defined by the POSIX standard.
In all cases, take care that resources and state are restored to a condition consistent with the point of origin.
Be careful to cancel a thread only when cancellation is safe. The pthreads standard specifies several cancellation points, including:
Programmatically establish a thread cancellation point through a pthread_testcancel(3T) call.
Threads waiting for the occurrence of a particular condition in pthread_cond_wait(3T) or pthread_cond_timedwait(3T).
Threads waiting for termination of another thread in pthread_join(3T).
Threads blocked on sigwait(2).
Some standard library calls. In general, these are functions in which threads can block; see the man page cancellation(3T) for a list.
Cancellation is enabled by default. At times you might want an application to disable cancellation. This has the result of deferring all cancellation requests until they are enabled again.
See "pthread_setcancelstate(3T)"for information about disabling cancellation.
