Solstice Enterprise Agents 1.0 User Guide
3.1.3 Communicating With the Subagent
Any communication from subagents to the Master Agent is done through UDP port 161. The topic of sending traps to the Master Agent from the subagents is discussed in "3.1.6 Trap Notification"on page 3-5.
Note -
The Master Agent communicates on separate ports for each subagent.
The Master Agent also checks to be sure that registered subagents are up and running, based on the following conditions:
