Solstice Enterprise Agents 1.0 User Guide
7.2.1 dmi_cmd Examples
7.2.1.1 Example 1
The following command lists the component ID, name, and description of up to 5 components, starting from component 3 in the dmispd running on the host snowbell, by using the default request mode (DMI_UNIQUE).
%dmi_cmd -s snowbell -CL -d -c 3 -m 5
Connecting to dmispd on the snowbell...
CompId: 	4
Comp Name:	DMTF Developers -  Direct Interface Version
Description:	A list of the people who actually wrote the code.
CompId: 	5
CompId: 	6
CompId: 	7
CompId: 	8
7.2.1.2 Example 2
The following command lists the ID, name, storage, access mode, date type, and maximum size of all attributes in group 1 of component 1 in the dmispd running on local host, by using default request mode (DMI_UNIQUE). No description is displayed, and no limitation is set for max count.
%dmi_cmd -AL -g 1 -c 1
Connecting to dmispd on the localhost...
12 attrs listed for group 1 of comp 1
Attr Id:	1
Storage:	MIF_COMMON
Access:		MIF_READ_ONLY
Type:		MIF_DISPLAYSTRING
maxSize:	64
Attr Id:	2
Storage:	MIF_COMMON
maxSize:	64
Attr Id:	3
Storage:	MIF_COMMON
maxSize:	64
Attr Id:	4
Storage:	MIF_SPECIFIC
maxSize:	64
Attr Id:	5
Type:		MIF_DATE
maxSize:	0
Attr Id:	6
Type:		MIF_INTEGER
maxSize:	0
Attr Id:	7
Type:		MIF_INTEGER
maxSize:	0
Attr Id:	8
maxSize:	256
Attr Id:	9
maxSize:	256
Attr Id:	10
Type:		MIF_INTEGER
maxSize:	0
Attr Id:	11
maxSize:	256
Attr Id:	12
maxSize:	256
7.2.1.3 Example 3
The following command installs namedir.mif in dmispd running on localhost. The file namedir.mif is located in the directory specified in the configuration file.
%dmi_cmd -CI namedir.mif
"namedir.mif" is installed as comp 21.
7.2.1.4 Example 4
The following command uninstalls component 5 in dmispd running on localhost.
%dmi_cmd -CD -c 5
comp 5 is uninstalled.
7.2.1.5 Example 5
The following command displays the version of dmispd running on the snowbell machine.
%dmi_cmd -s snowbell -V
dmispd version:	Dmi2.0
description:	This is a DMI2.0 based on ONC RPC
