Solaris 7 3/99 Online Release Notes (SUNWrdm)
SPARC only: Java on SPARC Dumps Core (4087298)
Random bus error or segmentation fault occurs in an application or support library.
Workaround: Use java_g or java -debug to run this program. Also, try turning the JIT off:
setenv JAVA_COMPILER NONE
Any of these workarounds change the execution profile of the VM.
