Solaris 7 3/99 Online Release Notes (SUNWrdm)
AnswerBook2 Server Administrative Access Authentication Fails (4113327)
AnswerBook2 server administrative access authentication fails if you use a CGI-based http server instead of the default NSAPI server.
Workaround: Perform the following steps:
  1. Become root on the document server.
  2. Turn off administrative access control for the document server by typing the following command:
    # /usr/lib/ab2/bin/ab2admin -o access_off
  3. If you still need to control access to administrative functions on the document server, use available commands on your http server to restrict access to the following URL:
