Solaris 7 3/99 Online Release Notes (SUNWrdm)
Supported Y2K Dates Testing Procedure
CDE and Solaris 7 is Y2Kcompliant. Use the date command to modify the system date and clock. If you want the system date and clock to reflect a future date for testing purposes, halt or shut down the system and run in single user mode. You can only modify the system date in single user mode. You can then boot your system and run in multi user mode with the desired test date.
