Solaris 7 OnLine Release Notes (SUNWrdm)
During Installation
The following bugs only occur during an installation.
Erroneous Messages Indicating Packages Added A Second Time (1235464)
This appears as an attempt to install the same architecture and version of a package that is already installed. This installation overwrites this package.
When upgrading a system with the "Entire Distribution plus OEM Cluster," the following packages seem to be added twice:
Workaround: If you try to add a package that has already been installed on a system, the installed package is overwritten.
Installation Progress Bar May be Inaacurate (1266156)
The "Installing Solaris Software - Progress" bar sometimes indicates that an installation is complete when it is still in progress. The install program may add packages for several minutes after the progress bar has indicated that the installation is complete.
Do not rely on the progress bar to indicate that the installation is complete. The installation displays the following message when the program has completed all installation operations:
Installation complete
JumpStart Installs on Wrong Default Boot Disk (4027156)
JumpStart does not install the default boot on the current default boot disk under some conditions. A condition under which the problem has been observed involves using a fully automated install on a SPARCstation 5 with two hard disk drives. Therefore, the previous version of the Solaris operating environment is booted instead of the current one when you reboot.
Workaround: Install the Solaris operating environment without JumpStart.
Installation of Diskless Client Does Not Preserve Changes in dfstab File on Server (4045544)
When you upgrade the Solaris operating environment on a server with diskless clients, the options on the dfstab line are not preserved for /usr. For example, if you entered the following in the dfstab file,
share -F nfs -o rw /export/exec/Solaris_2.7_sparc.all/usr
then this entry is automatically replaced with the following entry during the upgrade:
share -F nfs -o ro /export/exec/Solaris_2.7_sparc.all/usr
Workaround: Before you attempt to upgrade the Solaris operating environment on an OS server that has a diskless client or AutoClient, back up the /etc/dfs/dfstab file for the clients.
