Solaris 7 OnLine Release Notes (SUNWrdm)
Java Applications Dump Core When There Is Insufficient Swap Space (4037312)
Java applications dump core when there is not enough swap space. The application indicates the following bus error:
not enough space
Workaround: Exit other applications running on the system or add more swap space. See the System Administration Guide, Volume I for details on adding swap space.
