Solaris 7 5/99 Release Notes (SPARC Platform Edition)
XIL may no longer be supported in a future release. The following warning is generated when an XIL program is compiled:
#error: "XGL has been declared Obsolete and may not be present in versions of Solaris after 8.#define SUNXIL_WARNING_DISABLE (or use -D) to disable this message."
To compile an XIL program, disable the message by adding #define to the program:
or by using the following compiler directive:
