Solaris 7 5/99 Release Notes (SPARC Platform Edition)
init Prompts for Run Level When the reboot Command Is Executed From a Standalone Session (4191148)
A misleading message is sometimes displayed on the device on which you initiated the init state transition when administering a system using the init command even though you executed the reboot command. When executing init s, a single-user shell is established on a remote console and the subsequent rebooting of the system can cause the following message to be displayed:
Enter run level
Workaround: Ignore the misleading message.
