Installing the SUNWab2u package before the other AnswerBook2 packages, SUNWab2r and SUNWab2s, causes the following:
Warning messages will display during the installation
The scan option will not find any AnswerBook1 collections
Links between books will attempt to retrieve the book from docs.sun.com, rather than from the local server
Workaround: Use the installer (Web Start utility) or the pkgrm command to remove the SUNWab2u, SUNWab2r, and SUNWab2s packages.
To install the packages in the correct order, use the installer (Web Start utility).
If you install the packages manually using the pkgadd command, install them in the following order:
SUNWab2r
SUNWab2s
SUNWab2u
