Solaris 7 (Intel Platform Edition) 8/99 Release Notes
Upgrading With Disk Space Reallocation Removes Language Packages (4258815)
An upgrade using disk space reallocation in which the /usr partition is resized or moved causes some language packages to be removed from the system. The packages appear in the package database as installed, but the language files are not installed on the file system.
This does not occur on systems installed with only the English language.
Workaround: You may choose one of the following workarounds:
