When running the AnswerBook2 server with the command ab2cd, if LC_ALL is set to a value other than C or blank, you will see the following error message:
Internal Server Plugin Error ../dwinterp/dwinterp.cc reported TCL script exception: File not found: "/tmp/.ab2/data/config/dynaweb.dwc" ------------------------------ Please notify your System Administrator.../dwsp/dwspns.cc reported "Null Pointer" exception caught in ../dwsp/dwspns.cc, line 244 Please notify your System Administrator. |
Workaround: Before starting ab2cd, type the following command:
# unsetenv LC_ALL |
