Solaris 7 (Intel Platform Edition) 8/99 Release Notes
UFS Quotas Not Enabled After Booting (4226352)
If you have UFS file systems listed in /etc/vfstab with quotas enabled, you must apply the following workaround. Otherwise, quotas are not enabled automatically after booting a system.
Workaround: You must run quotacheck -a and quotaon -a for quotas to be correctly enabled. Otherwise, quotas remain disabled.
