Solaris Naming Setup and Configuration Guide
How to Limit Read Access to the Passwd Column
  1. Log in to the domain's master server.
    The examples in this task use the root master server, rootmaster.
  2. Check the current table and column permissions.
    Use the niscat -o command.
    rootmaster# niscat -o passwd.org_dir
    This task assumes the existing permissions are:
    Access Rights    : ----rmcdrmcdr---
    Columns          :
                         [0]  Name              : name
                               Access Rights : r-----------r---
                         [1]  Name              : passwd
                               Access Rights : -----m----------
                         [2]  Name              : uid
                         [3]  Name              : gid
                         [4]  Name              : gcos
                               Access Rights : r----m------r---
                         [5]  Name              : home
                         [6]  Name              : shell
                         [7]  Name              : shadow
    If your permissions are different, you may need to use a different syntax. For instructions, see the rights chapter of Solaris Naming Administration Guide.
  3. Change the table permissions.
    Use the nischmod command to change the table's object-level permissions to ---- rmcdrmcd ----
    rootmaster# nischmod og=rmcd,nw= passwd.org_dir
  4. Change the column permissions.
    Use the nistbladm command with the -u option to change the permissions of the passwd and shadow columns to:
    passwd ---- rm-- ---- ----
    shadow ---- r--- ---- ----
    rootmaster# nistbladm -u passwd=o+r, shadow=o+r passwd.org_dir
  5. Verify the new permissions.
    Use the niscat -o command, as you did in Step 2. The permissions should look the same as they do in that step's output.
