Solaris Naming Setup and Configuration Guide
Adding Compatibility With +/- Syntax-Task Map
Table 1-3 Adding Compatibility With +/- Syntax
Task
Description
For Instructions, Go To
Modify the /etc/passwd, /etc/shadow, and /etc/group files to add DNS compatibility with +/- syntax.
"How to Add DNS Compatibility With +/- Syntax"
