Solaris Naming Setup and Configuration Guide
NSKit Discontinued
The most recent Solaris releases have not included NIS service. Up to now, NIS service had to be installed from the unbundled NSKit. NIS has now been included in the base Solaris 7 release, and there is no 7-level NSKit.
Because NIS service is now part of the base Solaris 7 release, the SUNWnsktu and SUNWnsktr packages no longer exist. Instead, NIS is now installed via the Solaris 7 release SUNWypu and SUNWypr packages.
NIS service is no longer started with the /etc/init.d/yp script, which no longer exists. With the Solaris 7 release, you first configure your master server NIS maps with the ypinit script, then start NIS with the /usr/lib/netsvc/yp/ypstart script (these steps are described in detail in the following sections of this chapter). NIS service is stopped with the ypstop command.
