Solaris Naming Setup and Configuration Guide
Passwd Files and Namespace Security
The passwd map is a special case. In addition to the old Solaris 1.x passwd file format, this implementation of NIS accepts the Solaris 7 release /etc/passwd and /etc/shadow file format as input for building the NIS password maps.
For security reasons, the files used to build the NIS password maps should not contain an entry for root, to prevent unauthorized root access. Therefore, the password maps should not be built from the files located in the master server's /etc directory. The password files used to build the password maps should have the root entry removed from them and be located in a directory that can be protected from unauthorized access.
For example, the master server password input files should be stored in a directory such as /var/yp, or any directory of your choice, as long as the file itself is not a link to another file and its location is specified in the Makefile. The /usr/lib/netsvc/yp/ypstart script automatically sets the correct directory option according to the configuration specified in your Makefile.
If your source files are in a directory other than /etc, you must alter the PWDIR password macro in the Makefile to refer to the directory where the passwd and shadow files reside, changing the line PWDIR=/etc to PWDIR/your-choice, where your-choice is the name of the directory you will be using to store the passwd map source files.
Caution - Caution -
Be sure that the passwd file in the directory specified by PWDDIR does not contain an entry for root.
