Solaris Naming Setup and Configuration Guide
Default NIS Maps
Table 10-3 describes the default NIS maps, information they contain, and whether the operating system consults the corresponding administrative files when NIS is running.
Table 10-3 NIS Map Descriptions
Map Name
Corresponding NIS Admin File
Description
bootparams
bootparams
Contains path names of files clients need during boot: root, swap, possibly others.
ethers.byaddr
ethers
Contains machine names and Ethernet addresses. The Ethernet address is the key in the map.
ethers.byname
ethers
Same as ethers.byaddr, except the key is machine name instead of the Ethernet address.
group.bygid
group
Contains group security information with group ID as key.
group.byname
group
Contains group security information with group name as key.
hosts.byaddr
hosts
Contains machine name, and IP address, with IP address as key.
hosts.byname
hosts
Contains machine name and IP address, with machine (host) name as key.
mail.aliases
aliases
Contains aliases and mail addresses, with aliases as key.
mail.byaddr
aliases
Contains mail address and alias, with mail address as key.
netgroup.byhost
netgroup
Contains group name, user name, and machine name.
netgroup.byuser
netgroup
Same as netgroup.byhost, except that key is user name.
netgroup
netgroup
Same as netgroup.byhost, except that key is group name.
netid.byname
passwd, hosts, group
Used for UNIX-style authentication. Contains the netname database. If there is a netid file available it is consulted in addition to the data available through the other files.
netmasks.byaddr
netmasks
Contains network mask to be used with IP subnetting, with the address as the key.
networks.byaddr
networks
Contains names of networks known to your system and their IP addresses, with the address as the key.
networks.byname
networks
Same as networks.byaddr, except the key is the name of the network.
passwd.adjunct. byname
passwd and shadow
Contains auditing information and the hidden password information for C2 clients.
passwd.byname
passwd and shadow
Contains password information with user name as key.
passwd.byuid
passwd and shadow
Same as passwd.byname, except that the key is user ID.
protocols.byname
protocols
Contains network protocols known to your network.
protocols.bynumber
protocols
Same as protocols.byname, except that key is protocol number.
rpc.bynumber
rpc
Contains program number and name of RPCs known to your system. Key is RPC program number.
services.byname
services
Lists Internet services known to your network. Key is port and protocol.
services.byservice
services
Lists Internet services known to your network. Key is service name.
ypservers
N/A
Lists NIS servers known to your network.
