Solaris 7 (Intel Platform Edition) 11/99 Release Notes
Products May Not Use All Reserved Space (4059182)
Solaris Web Start reserves disk space based on the total requirements of all the products that you install. If you check disk space allocation after installing but before using the products, you may find a substantial amount of apparently unused space. Some of this space may be taken up when you run the software; some of it may remain unused.
Workaround: If you want to allocate less total disk space than Solaris Web Start requires, use the Solaris Interactive Installation program instead.
