Solaris 7 (Intel Platform Edition) 11/99 Release Notes
Installation of SUNWxilrl Partially Fails on Upgrade (4276484)
If SUNWxilrl is installed on a system being upgraded to the Solaris 7 11/99 operating environment and the /opt directory is on a file system that is being resized or moved during the upgrade, you will see the following error messages:
ERROR: attribute verification of </a/opt/SUNWits/Graphics-sw/xil/lib/libxil.so> failed
    pathname does not exist
    unable to create symbolic link to </usr/openwin/lib/libxil.so.1>
ERROR: attribute verification of </a/opt/SUNWits/Graphics-sw/xil/lib/libxil.so.1>
failed
pkgadd: ERROR: postinstall script did not complete successfully
Installation of <SUNWxilrl> partially failed.
pkgadd return code = 2
This partial failure results in the following:
Workaround: Recreate the directories and symlinks after the upgrade has completed.
  1. Complete the upgrade.
  2. Reboot the upgraded system.
  3. Recreate the xil/lib directory:
    # /usr/sbin/install -d -m 0755 -u bin -g bin /opt/SUNWits/Graphics-sw/xil
    # /usr/sbin/install -d -m 0755 -u bin -g bin /opt/SUNWits/Graphics-sw/xil/lib
  4. Recreate the symbolic links:
    # ln -s /usr/openwin/lib/libxil.so.1 /opt/SUNWits/Graphics-sw/xil/lib/libxil.so
    # ln -s /usr/openwin/lib/libxil.so.1 /opt/SUNWits/Graphics-sw/xil/lib/libxil.so.1
